Visual editing (WYSIWYG)
#105
Press ESC and formatting will be applied, so the link will become clickable!
#106
2 cents drop.
  • I like markdown but besides the bullet point * I mostly write it using keyboard shortcuts where supported. So ctrl b for bold in Dynalist or Reddit Enhanced Suite.
    • So, it you want to switch MD to WYSIWYG – no problem. Same keyboard shortcuts, same result :wink:
  • I love markdown in txt files; styling information in plain text.
    • so…if you do go WYSIWYG 100%, then export to MD should be an option
