- Zoom in to a Parent Node that is collapsed
- Put the cursor on a child node
- Use keyboard shortcut to zoom out
I will be zoomed out and the cursor will be placed in the parent node, so I can continue working with keyboard-only
The cursor is not placed, I have to use my mouse to click the cursor into where I want it
Mac OS Catalina
Which browser are you using?
Chrome and Desktop App (tested on both and bug is same on both)
If youâre using a desktop or mobile app, whatâs the version number of Dynalist?
1.4.4.
No
Screen recording of the bug here:
