Choose Import from WorkFlowy
Enter WorkFlowy email
Enter WorkFlowy password
Login to WorkFlowy and choose Import
Fail to login to WorkFlowy
this is not surprising as Work Flowy uses 2FA, actually 3FA by sending me an email code and also requiring my Authenticator
Mac Ventura OS 13.4
Which browser are you using?
Chrome
Don’t know where to find this - just started newbie
No
Wed, Jun 7, 2023: 2FA not currently supported with WorkFlowy imports
