Feeling a bit reluctant cause I donāt want to appear nagging about this - but do you plan to reimplement WordCount again in mobile views again, or will it be confined to the desktop view on laptops permanently?
Just in my case it proved to become a tremendous help in my daily professional work and speeded it up a lot and even made it possible to move all my working into dynalist which provided a lot of comfort and speed.
To give a little background, I professionally write texts for two bigger webprojects and do so on tablet most of the time. Every paragraph of a given structure has to fit into a certain word range so that the whole thing looks as planned then for the company. Permanently switching back and forth between the input and a word counting app to check if youāre in the given word number range is a pain in the ass as you might imagine.
Dynalist in Chrome on Android is very poorly usable when you activate desktop mode of webpages indeed to have the functions, so thatās not really an option (guess thatās why they made mobile views for a good reason). The more just lately it started to live count only in items when you zoom into a single item with note attached, not in the notes, even in desktop mode. For me it worked pretty fine in mobile view (app on android 7) when it first was in but I assume there have been troubles in the background.
Iām aware that this is a pretty special usecase of course and that - given the statistics - mobile use of dynalist isnāt very common obviously anyway. For me itās just important to have some information about if this ever going to work again - or if I have to re-design my workflow back to where it was before (lacking the structure then that dynalist provides, which would be a pity but well).
Thanks
