I genuinely canāt imagine someone voting no. Even if they wanted to paste plain textāa perfectively reasonable intention I often want to haveāthereās an easy way to achieve that in a system where formatting is by default preserved (paste into a plain text editor or something, then copy that), whereas there isnāt as easy a way to preserve formatting in a system that by default loses it.
User information should not be (implicitly) destroyed. Users should not be surprised.
Hi there!
Iām getting the same here: italics and bold are lost when I copy a texto from one bullet point and paste it into another one. Also, if I copy some text from a MS Word document and paste it into Dynalist, the italics and bold are gone. Is there some way to prevent this to happen? Iād really like to preserve the formatting when copying and pasting to Dynalist.
Thankās!
Thatās right, @JP1! I was about to write about this.
At the time when I wrote that, I was having trouble with preserving the formatting of texts copied from bullet points inside Dynalist. But Iāve recently made some tests and realized that this issue isnāt happening anymore. As for the material copied from Microsoft Word, the situation remains the same as Iāve described.
Iāve just made a test with Workflowy. It was interesting: if I copy a paragraph from a MS Word document and paste it with ctrl + v, the formatting is preserved but the text is āmutilatedā: instead of being on a single bullet point, the fragment is divided inte pieces, each one being on a different bullet point; on the other hand, if I paste the paragraph with ctrl + shift + v, it did not get mutilated, but all the formatting gets lost.
Hi there!
Is there some news about fixing this bug?
Just rememberig that the italics and bold are lost not only when the text is copied from a MS Word document; it also happens when the text is copied from a note at Evernote, for example.
Thankās!
