Good day Liamani. Recently someone else asked a similar question and I posted this: There are so many things to recommend in the forum here. For instance, check this out: https://talk.dynalist.io/t/how-do-you-use-search-and-tags-to-get-around/
Perhaps that may be helpful.
There is a lot in your inquiry there. Spending time on this forum using various search criteria will reveal some deep discussions on different approaches people use.
I think when starting out with a tool like this one will likely end up trying out different structure~patterns before landing on something that actually works. Patience and time were required in my case, and I am still working on formulating ‘better methods’. ::sigh:: (lol)
The de-duplication thing is a little challenging in Dynalist. Some other outliner~type softwares provide facility for “full inclusions” from various parts of your lists, so that a “link” to another entry somewhere will/can include the whole ‘other entry’ contents …Dynalist does not have this feature, so here then you have to sculpt your method of managing the data list-to-list accordingly.
Of course, the search function in the upper right is your friend for local or documents~scope searching (the help menu, under the upper-right hamburger menu, will lead you to the knowledgebase for unlocking all the particulars). The link above (in my post) should help lead you into myriad discussions for a deeper understanding of how to leverage complex tagging and searching methods for taming cross-lists access.
“stylish practices…” For myself, and I have posted in detail on this elsewhere, I found I had to boil the scope of my “particulars” into fundamental categories (for me ‘4’) in order to manage distinctive flows vs their crossover with one another. I wont go into too much detail here, but say…
…say I am managing people/workers, places/jobsites, resources/materials and time/project~flows…
As a loose [partial] example then, one document focuses on divisions of jobsites with a breakout under each for its’ projects, but then each project has its own document focusing on its’ unique [multidimensional] structure -for maintaining integrity/continuity for it as a whole. Then there’s time/sheets and people
…bottomline is tagging and formulating complex seaches (search patterns I can save) then allow me to pull filtered views from various lists together to see what I need, for instance…
- this aspect of that project with these people on a specified date
- this company/person and the jobs they are working on
- could be on a specified jobsite, or all the sites/projects I have them retained for
- etc
I hope this was helpful …at all. There are some folks here who are way more advanced at using these types of tools, and coming from higher scholastic understandings than I yet have.
Good luck!
