Vivaldi Browser was mentioned in another post but this shows how i use it. It almost feels like a expansive heads up display This is the closest thing i can get to a horizontal view
Thanks for the idea! I hadn’t considered doing this with Vivaldi before. Very cool.
This is moving into Kanban territory…
For moving between horizontal panes I use:
click into item to be moved -> ctrl+a twice -> ctrl x —> go to new location -> ctrl v
I find this perfectly good and very quick - probably similar in speed to a true drag and drop and more accurate / less clumsy - I suspect I would still use this even if drag and drop between panes existed
Possibilities are more than Kanban,
i and maybe others like thinking horizontally and vertical, it makes the tool more flexible.
Not to mention it’s better use of widescreen space and there is no back and forth between viewing lists. Its a basic usecase, it’s like having two browser windows open side by side or two documents open. Those reasons and more make this legitimately more than just a Kanban view
Hello. I use vivaldi with Dynalist with horizontal tabs. How do you configure your layout ? Thank you.
I also use the great Vivaldi browser (my default) with Dynalist.
I simply keep 3 Dynalist tabs (at least) permanently open in a separate Vivaldi window, clustered in a single tab, so that I can take a quick look at 3 various Dynalist lists without having to switch away from them.
If I do need to go quickly to another list, I do that via the keyboard shortcut (CTRL+SHIFT+O for me) or via that list’s bookmark in the Bookmarks panel.
(I keep the Bookmarks panel permanently visible in one of the 3 Dynalist tabs I have open permanently.)
Just wanted to say (bring attention as) it’s amazing, I’ve used it for school before and since coming across this post I’ve started tweaking it an even on android it’s far better and performant as I thought (being chromium, not neccessarily having this tiling) I’m currently transitioning for the most part…
