Unable to copy spaces in the code block
Manually use mouse to select and copy any code containing spaces from the browser or vscode or dynalist itself, then paste them into the code block in dynalist
code block
spaces remain the same as the original code
spaces disappeared
Which operating system are you using? Linux
Which browser are you using? Firefox
Peek 2023-09-07 14-36
Sorry, I could not reproduce that on my computer. See, the tabs are correctly pasted. I also tried 4 spaces in place of tabs which also look the same. image
Can you try opening an Incognito window and going to https://dynalist.io/demo to try it there, and see if it still happens there?
I tried and the issue remains. when I copy the same content to mail text editor or vscode the blank/tab are correct
did you click the ‘copy’ button or manually select all text and paste? make sure to manually select instead of using ‘copy’ button in dynalist code block
test
	test
		test
			test
		test
sorry turns out it’s a vscode issue, ctrl shift v to copy plain text works fine
