Tracking Document Changes
Is there a way to track the changes made in a document? For example, Workflowy has a feature of sending you daily emails outlining the changes/deletions you’ve made.
There is a Version History feature. Pro-only I expect. Right click on the file in the Files pane and click Version History. It shows you before/after of a cluster of changes. This isn’t a list of just changes, though.
Another process is to use the daily backup. You can extract OPML from yesterday and today and send these through a Diff program to see what changed.
Incidentally if you point at a bullet it will show you when it was last changed.
Sweet, thank you so much!
