Hi all,
I just noticed something that might make your dynalist mobile life 0.1% better - if you’re editing an item, the quickest way to exit edit mode is to start sliding the current item to the right i.e. begin the ‘check off’ process, and then slide it back to the left to cancel. That removes the cursor from the current item and minimises the keyboard.
Before this, I used to double tap the ‘lock’ button in the top right.
Best,
Stephen
