I was surprised to find that the content and the result of the backlink overlap (see the bullets on the left, because I am not convenient to display the content due to privacy issues). I will quote different contents of the same document in the document, and backlinks will appear at the bottom. When I click the backlinks and then enter new content from the backlinks, I found that the content overlapped.
I hope that the content will not overlap.
Which browser are you using?
MacOS 13.1 (22C65), dynalist desktop 1.5.1.
