Write some shell command line snippets as multi-line code blocks (triple backticks):
Syntax highlighting makes sense or there no highlighting at all.
Highlighting seems random. The worst - some executable code rendered as comments (marked on screenshot)
Which browser are you using? Chrome 89.0.4389.90
If youâre using a desktop or mobile app, whatâs the version number of Dynalist? Desktop and web 1.4.5
This is probably due to language (mis)detection. If itâs impossible to do get it right, there must be an option to disable. Wrong highlighting is much worse than no highlighting at all
