Sync undo deleting stuff
I deleted a folder on the Windows app. After it was synced the deleted folder reappeared.
The folder deleted permanently
If reappeared after my app had been synced.
If you’re using a desktop or mobile app, what’s the version number of Dynalist? 1.4.4
Were you able to delete it from the webapp?
Hi Shida,
Now it works! But it did not work before both on my app and webapp.
Thanks,
Pancha
