I use Dynalist for almost all of my brainstorming and planning.
I had spent hours writing up some notes a few days ago. I was using my other laptop and opened up Dynalist. It took longer than normal to sync but my notes were nowhere to be found. I returned to my primary laptop and opened Dynalist. I see my notes⦠and then it āsyncsā and those specific notes that didnāt sync to the other laptop straight up vanish.
What the actual hell? I lost hours of work. As it is, I rarely delete notes and I frequently use Dynalist to jot thoughts/data to be able to search for later. As a paying customer, this is absolutely unacceptable and a nightmare. Iām not sure what else I may have lost in these āsync issuesā.
I had set up backups with Dropbox years ago and now I just checked for a backup. Despite saying Dropbox was linked, my most recent backup in Dropbox is from 2019! If it wasnāt making backups, why didnāt it notify me or why did it say it was linked?
Lets focus on getting your notes from a few days ago back first, then switch focus to the issues that caused it after. @Shida and @Erica might have more ideas too
Go to version history (not dropbox, itās a independant thing in the document right click menu)
See if you can find your notes there and copy and paste them into a text editor
So it was the Dynalist desktop app where you wrote the notes and they vanished before your eyes in? Are you on mac? Do you have Time Machine on? I think the app stores documents in /Users/me/Library/Application Support/Dynalist/dynalist/data before syncing but I am not sure how mac file history works, Iāve never been in that situation, just throwing out more ideas.
Sorry just caught wind of this. Could you provide a bit more details on your setup - are you using the desktop app on both your sessions, or the web app? Thereās a few things we can do to debug this issue - your notes may actually still be around on your computer if youāre on desktop and we can help you recover those.
As for Dropbox backups, I believes sometimes the authorization token gets revoked after a while, but in my experience Google Drive does this way more often than Dropbox. We usually send an email about this so you can re-setup the authorization, not sure why you didnāt get it.
You can also contact support via email and we can help you through the recovery process.
Iāve been having this problem for at least a month now, if not longer. Up until today, I usually only lost a line or two and nothing too important. It was annoying, but it wasnāt a deal-breaker.
Today I lost a whole paragraph that was important to me, and then I noticed that higher up in the document a few lines were missing (probably an issue of an earlier sync I didnāt notice). Thankfully, I managed to recover the long paragraph by ctrl+Zing on desktop, but Iām not even sure what exactly was in the few lines I lost above it - I can see somethingās missing because I remember typing one of them, and also whatās left in the document doesnāt make sense.
I can live without these few lines, but itās a recurring issue and it just canāt keep happening. One of these days Iām going to really lose something vital (today came close). My guess is that itās a sync issue (I use Dynalist both on mobile/Android and on desktop/Firefox) similar to what the OP talked about. I did notice a delay in syncing before, which is fine. Losing data to sync is not fine. Could this be a problem between prioritising which version should overwrite which version?
I hope this is going to get fixed, or Iām going to have to go on another journey of finding a productivity/note-making app that works for me
