Swap with previous/Swap with next Shortcuts No Longer Work
Create a list with two items. Select the top item. Press Ctrl+Down
The two items should swap, moving the selected item down to be the second item in the list.
Nothing at all. The items stay in place. This used to work, but stopped working a few weeks ago. I’m not aware of any changes made on my end that would’ve caused the issue (i.e. always using same browser etc).
Which operating system are you using? Windows 11 Pro
Which browser are you using? Chrome - latest version
If you’re using a desktop or mobile app, what’s the version number of Dynalist? Desktop - I’ve refreshed to be using the latest version.
Are you using any third-party scripts for Dynalist, e.g. PowerPack? No.
Mine work. Hotkey priority is Operating System, then Extension, then Website, so perhaps something in a higher priority has binded to ctrl up and ctrl down as their own hotkey, in which case the website won’t detect it anymore. Just an idea.
Thanks. Went through and disabled my extensions one by one, and eventually discovered that one of those was causing the problem. Removing it has fixed this back up. Appreciate the help!
