Suggestion: Editable Mind Map
It would be great if the mind map view is editable. I found mindmap a great way to capture notes and ideas because in 2 dimensions it’s easy to start new top-level topics and drill down. Apps like MindManager and MindNode have good keyboard navigation. It’s possible to use all 4 direction cursor keys as well as tab/shift-tab/return to naturally move around the map.
