In the latest iPhone OS on the web app, Dynalist opens and flashes a help tip suggestion for a couple seconds, disappears and shows my list, then flashes another help tip suggestion over and over and over again and won’t stop. Been doing this for weeks. How do I turn this off so it stops or is there a bug fix coming?
That sounds awful. Try uninstalling and reinstalling the app. Or clear the data&cache if you know how. Uninstall does this.
You’re the only person to ever report this, so it doesn’t seem to be widespread.
Which model do you have?
