- Create a document
- Bookmark it via the star near the title
- Unbookmark it
- Tap/hold
Ctrl + Aand delete the title to replace it with something else. - Itāll detect that the title is empty and will try to rename it as Untitled
I want to replace the title.
Sometimes as Iām typing the new title, itāll erase whatever Iām writing and save an older version of the title on top of whatās written (instantly).
Dynalist Chrome, Windows 10. Iām also using Phraseexpress, but I doubt thatās causing the problem.
Switching from the bookmarkās pane to the file pane seemed to resolve the issue for me.
Edit: I was on a different tab and it reverted the document to an older version and delete the note that I had in the title. @Shida, do you have any ideas as to what might be causing this? My other documents appear to be just fine.
I also canāt paste links in the title. Itās so strange.
Update: Iāve created a new document to avoid the hassle, but the note that I created was mysteriously deleted for some reason. I hyperlinked some words in it, so I donāt know if thatās the root of the cause.
