Try to use any of the following commands while using a keyboard with Italian layout:
| Command | Shortcut | Notes |
| Format as code | Ctrl+` | Italian layout does not have a backtick key. |
| Zoom in previous item | Ctrl+Shift+[ | Italian layout requires AltGr to insert square brackets, this shortcut won’t work. |
| Zoom in next item | Ctrl+Shift+] | (see above) |
| Zoom in | Ctrl+] | (see above) |
| Zoom out | Ctrl+[ | (see above) |
| Toggle help | Ctrl+/ | The numpad has this character the hotkey is not working. |
As with English and German, the Italian keyboard layout can be selected in the settings so I can use the hotkeys displayed in the “Shortcuts & Formatting” section of the main menu. Note that virtually all computers and keyboards sold in Italy have this layout.
Using the suggested hotkeys has no effect.
I’m using a laptop with an integrated Italian layout keyboard
Dynalist desktop app 1.5.1
Windows 10 64bit latest version (10.0.19045) - Note I had this issue for years though
I’m on a Free account and never changed hotkeys
In the “Shortcuts & Formatting” section it should be mentioned that these two commands work only when already in Search mode (CTRL+F):
- Search everywhere
Ctrl+↵ - Enter flat search
Shift+↵
