I set showing only 1st line of notes. Problem: I can’t see if the note has only this line or it has more lines.
Workflowy shows 3 points at the end of 1st line if the note has more lines.
The “…” does appear in Chrome and the desktop app, at least.
Which browser are you using?
I’m using Chrome 57.0.2987.133 on Mac OS 10.12.4 and “…” doesn’t appear, unfortunately.
Hi @Erica I also don’t see the “…” in notes with multiple lines- Mac desktop app (1.0.29)
@drichli and @Mark_Gammon: thanks a lot!
I verified, on Mac Chrome the “…” indeed doesn’t appear. Looks like we’ve disabled it for Mac/iOS because a long while ago it wasn’t properly supported in iOS Safari. Now seems like support is here, we just need to carefully check that nothing goes wrong and add it back.
