Shortcuts on International Keyboards
Change keyboard to an European layout (PT-PT in my case)
Type Ctrl+Shift+โ€™ (Shift+โ€™ = โ€œ?โ€)
The shortcuts window should pop up.
Nothing happens.
Which browser are you using? Windows desktop
If youโ€™re using a desktop or mobile app, whatโ€™s the version number of Dynalist? 1.5.1
I came across this article on International Keyboard Shortcuts Why Keyboard Shortcuts donโ€™t work on non-US Layouts and how Devs could fix it ยท tkainrad
