Hello,
is there a way to set a shortcut for the companion clipper? (Firefox)
For example if I select a block of text I don’t want to do right click -> left click to safe it to Dynalist. A shortcut got that would be nice.
Thank you!
Hello,
Thank you!
Unfortuantely, I don’t think Dynalist’s Firefox clipper has a registered shortcut.
You can set the Chrome clipper shortcut in extensions - shortcuts like so:
On Firefox I see this:
So it looks like we need to look into how to register a shortcut with Firefox specifically. I’ll see what we can do!
Thank you!
Just released version 0.4 where you can set a shortcut to activate the clipper. So after selecting text, use the shortcut to capture, and then Ctrl+Enter to send.
I hope that helps!
Implemented less than 24h later. What a Service, thanks!
I have the shortcut set as Shift+Command+C
But I already use that shortcut for another application.
How can I change the shortcut?
chrome://extensions/shortcuts
