Several times in the last day or to a saved link did not appear in my inbox.
This appears random. Seem like it happens more when the Dynalist app is âcoldâ (not opened in a while).
Install dynalist on Androind
Open website in browser
Click âShareâ
Select Dynalist
Press âAddâ on pop-up
Check Dynalist Inbox for link
Link in Inbox
Sometimes link not in Inbox
Which operating system are you using? Android
Which browser are you using? FireFox
If youâre using a desktop or mobile app, whatâs the version number of Dynalist? Mobile
Hmm, Iâm guessing this only happens when you donât have the inbox document open, could that be the case? Could you try staying on that document and let me know if that makes the issue go away? If it does, then I might have some ideas to help.
Also just to make sure I understand correctly, once you âaddâ, and you immediately navigate to the inbox location, the item doesnât show up at all, is that correct? Does it ever show a message saying the item was successfully added?
The proplem is sporadic. I can not reproduce it reliably and do not recall allspecific details. I think it is reasonably likely I did not have Dynalist open when it occurred
Anything about this part? Iâm wondering if youâre leaving the app too quickly (so it never got a chance to save it) or whether the inbox tool is sometimes non-functional itself.
I mainly share from firefox. I do not know about other apps. Had a another ccase today. Seems to jappen when the dynalist app is âcoldâ - not been opened for a while. Once I visit the app,saving starts working. The main concern is silently losing saves when I do not check right away and forget I tried to save it. That is the point of âsavingâ afterall
While not a fix for this, one workaround is to use Quick Dynalist for capturing to inbox on Android, which works really well and has some other nice features like multi-inbox support.
