- Select âSettingsâ, on top right corner on Chrome browser
- In âPreferencesâ tab, select âHighlight current itemâ
- UNABLE to select the checkbox
- ABLE to select the checkbox
- Using Windows 10, and Google Chrome browser, latest version.
- Iâm able to change the setting on Mobile app, and it does work, but setting does not replicate on desktop
