Search shotcut not work
In a document, press the shortcut of “search everywhere" & “Enter flat search” dose not work(no respones)
It happends on both Mac or Windows or Web
Did I use the shortcut in a Steps to reproduce
Did I use the shortcut in a wrong way ?
It happends on both Mac or Windows(App Version 1.2.2) or Web
You need to enter a search term in the search bar first. Did you do that?
OK , Soga~ Thanks~ ^-^
Cool! I’ll close this bug then. Thanks for the reply!
