I will take a look at the Michael Linenberger methodology, and thank you for linking to that.
Do you not mark a project as complete after completion? I realize that there may be a framework where that’s not possible or practical, however, if you do, then of course it would be easy to do a search a la…
Requires a special tag for “marking” a project as completed, say “#PC”, and using #na for nextaction tagging…
-ancestor:#PC #na within:somedate
I am not using proper syntax there, its only representative of the simple idea.
It says search for NextActions, AND after/within a specified date tag if/as may be relevant (employing within/since/until operators AND/OR edited/created*), Whose Ancestor IS NOT Marked as ProjectCompleted (cannot use simple app “completed” mark since thats ambiguous, obviously).
*Using operators edited/created facilitates not having to manually date and item (project?) in relevant cases (of course). Adding the use of "within/since/until along with edited/created/ may facilitate making a better date frame where needed [?].
Considering your level I would assume you have already wrestled that one to its failed conclusion, but its worth noting since (if nothing else) it is not mentioned explicitly in this thread, AND you mention “searching under a project” which seems to imply all #na would appear within context of “a project document”.
Hmmm… still feeling I’m just not getting it, but thought I’d reflect back. I will be checking out the link you posted when I have more time, thank you.
Good luck, and, if nothing else, please post back your solution if/when you resolve the puzzle.
Thanks.
EDIT/ADDENDUM
It should be mentioned… I relate to NextActions differently from Immediate vs Steps (or Stages) vs Urgent…
I have not solved that management very well, but I use some qualifying NA Tags a la…
#NextAction = the next step in the project. Could also add a number at the end (in limited fashion) for more granularity, but I personally do not.
#NOW = what it says. If that gets posted, usually a #NextAction tag is already in there and the search filter would include both flags for filtering to and displaying those.
#NextStep = at some junctures in some projects steps or stages may be flagged. I can choose to include #NextAction (if/when makes sense, or not) depending on the filtering context targetted/anticipated.
#NextMeeting – I have some variations on these
#NextActionPriority = rarely used but it happens
Those types of flags always get removed as actions are performed.
– Sometimes it is necessary to flag something or a series of somethings as done, (the “completed” feature does not serve me well, so I use my own tagging for that …and actually I use a keyword method, not an actual tag, for this and certain other criteria [for various reasons of keeping things more easy to manage where tags may make it unnecessarily cluttered or difficult]).
– Sometimes it is necessary to flag a section in the timetracker OR the project …where critical notes were dropped in on the fly. I try to remove those as projects’ documentations may otherwise be properly updated, but sometimes it is necessary to keep them tagged for posterity (reference when a thing came about in due course).
LASTLY: I script/create my tags in anticipation of complex BOOLEAN Filtering. So for instance, sometimes a #NextStep includes some #NextAction/s and sometimes not. If I want to search all #NextSteps not having a #NextAction association (not the greatest example, but anyway…) I may Filter for…
ancestor: someProject #NextStep -#NextAction OR ancestor: someProject ancestor:#NextStep -#NextAction
…Meaning: Display Specified Project with NextStep/s not having a sibling or decendent NextAction
…kind of thing.
– I will create these “filters” and then either bookmark or make them available in a Filter Document for quick reuse and editing …can even link to them and give them meaningful names, like say … [Weekly Update XSystems at ZWorkSites wAssociate/s per Fleet Migration of xyz](link here to complex query).
…some of those queries are quite large, but can save me the need for creating separate documents or sections for things I see classically recommended in many GTD requiring either having to otherwise move things around (from where I think they should logically reside without being moved) or needlessly duplicate data.
I have no clue if any of that may be helpful (to you or someone else), or if its just more chaos, but there it is …some of my own ‘fighting the chaos’ in progress ;^)
