Seaching for Tagged But Not One Particular Tag
  • Create a document contaning a record with “foo #home” and another record w/“foo2”
  • Search for “# -#bar” (meaning “has a # and does not have #bar
Search results that contain the “foo #home” record.
No records.
Which operating system are you using? Windows 11
Which browser are you using? Edge.
If you’re using a desktop or mobile app, what’s the version number of Dynalist? 1.5.1
