I did a small outline of some of the features of the Mind Maps view.
Thank you for this! I haven’t played with the mind map view much, but your example makes me want to.
That’s super cool, Shaun! Takes for taking the time to make this
Can’t see the mindmapview. Is it broken?
Hi Kenneth,
Works OK for me when I am logged on. When I log off it says I must be a Pro user to see the mind map.
You are Pro user so you should be ok.
Suggest you try Dynalist support if the problem persists.
Regards
Shaun
Hi.
Yes thanks. That fixed the issue. Can’t wait for editing of mindmaps to be launched.
