Date formatting; resolved
What are your date/time formatting settings? That doesn‘t look like the defaults I am used to.
Yeah, like @_Lasar said, looks like something is wrong with your date customization?
Because MM is for months. mm is for minutes.
It’s explained in the docs ?
https://help.dynalist.io/article/92-preferences-reference#date-display-format
Yep, what @WhiteNoise said. You can notice that you used MM
twice and they did produce the same value (07
Can I ask how the specific date string !(2020-07-16 16:00 -04:00)
came to be, and if it is indeed valid?
It was my belief that a date or time range would absolutely need two dates, like this:
!(2020-07-16 16:00 - 2020-07-16 04:00)
And the missing space between -
and 04:00
is throwing me off as well.
(I’m working on a date parsing library for dynalist right now, so I want to make sure I’m getting all possible formats. If this is the wrong place to ask please let me know.)
“Developer” is probably a better subforum to ask. I thought you were asking for a feature for a second
The -04:00
part is your timezone. I believe if you don’t switch between time zones or collaborate with people in other time zones, you can uncheck “Encode timezone” in Settings - Preference - Date and it should go away. But yeah that part is your local timezone.
