In Evernote you can rename Tags in the Tag view. If one tag is used 50 times, you just have to rename it once, thereby changing it for all 50 tagged notes.
It would be very convenient to be able to do that in Dynalist. Otherwise you have to separately rename the tag in every item with that tag.
