On the android app, when the cursor doesnāt select any text and I press Ctrl+C then dynalist is copied to my clipboard.
This can be a problem when I want to paste something and I press Ctrl+C instead of Ctrl+V. Because of this I loose the text I want to paste.
Thatās weird, I donāt remember any instance where weād copy that into the clipboard. There was something for iOS devices but that doesnāt seem to be the case here.
