Here is how I got a widget/button on Android home screen that quickly adds an item to my Dynalist inbox. It uses Tasker, an Android automation tool.
In Tasker, add my âCapture to Dynalist Inboxâ task from TaskerNet (direct link)
Edit the task to enter your Dynalist API token where indicated. You can find your token at https://dynalist.io/developer
Add a widget to your home screen: Tasker -> Task Shortcut -> Capture to Dynalist Inbox
The widget may not always work, especially if your item has exotic characters, because I donât know how to properly escape special characters in the input before sending to the API. I have tried to handle backslashes and quotes correctly, though.
Here is the task description in case you are interested:
Task: Capture To Dynalist Inbox
<Enter your API token here:>
A1: Variable Set [
To: None
Max Rounding Digits: 3
Structure Output (JSON, etc): On ]
A2: Popup [
Text: You must first edit this task to enter your Dynalist API token
Layout: Popup
Timeout (Seconds): 600
Show Over Keyguard: On ]
If [ %dynalist_api_token ~ None ]
A3: Stop [
With Error: On ]
A4: Input Dialog [
Title: Capture to Dynalist inbox
Close After (Seconds): 30
Pre-Select Input: On ]
<Escape backslashes>
A5: Variable Search Replace [
Variable: %input
Search: \\
Replace Matches: On
Replace With: \\\\ ]
<Escape quotes>
A6: Variable Search Replace [
Variable: %input
Search: "
Replace Matches: On
Replace With: \\" ]
A7: HTTP Request [
Method: POST
URL: https://dynalist.io/api/v1/inbox/add
Headers: Content-type:application/json
Body: {
"token": "%dynalist_api_token",
"index": -1,
"content": "%input",
"note": ""
Timeout (Seconds): 30
Continue Task After Error:On ]
<Debug>
A8: [X] Popup [
Title: Debug
Text: %input
%http_data
Layout: Popup
Timeout (Seconds): 5
A9: Popup [
Title: Error Adding To Dynalist
Text: Received response code: %http_data._code
Layout: Popup
If [ %http_data._code !~ Ok ]
A10: Flash [
Text: Successfully added to Dynalist!
Continue Task Immediately: On
Dismiss On Click: On ]
If [ %http_data._code ~ Ok ]
