I would like to create a folder and then create an initial document within that folder almost like a common resource or FAQ document. As I create new documents in that folder they are created at the top and steadily push my initial document down. [QUESTION] Can I somehow pin a document so anything else created or placed in that folder are created or placed below the pinned top document?
I have the same question, hopefully there is a way…anyone?
Put the important document higher in the tree.
In other words, create a folder with 1 document and 1 folder inside, and that inner folder contains all the other documents.
