Use the copy link function from another app (nytimes). Access it from the share icon.
Paste the link into Dynalist or post it to dynalist
Link with the title and url
Just the title text, not linked
IOS and mac
The NYTimes appās share/copy function will paste the title first and the formatted link after.
The link pastes successfully on Android, so this might be an iOS issue.
Can you try selecting More and then select Dynalist to share the article to? (Instead of Copy)
Doing this will put the article in your designated inbox document.
Ios: First. I had to turn Dynalist on from one of the two More buttons. Next, Dynalist appeared as a Send target in the main icons. Tapping that gives me a send dialog, I click Send. The i see Dynalist with an add to Inbox dialog and I click Post.
Is one of those steps removable? Itās certainly redundant.
