I am encountering a java.lang.OutOfMemoryError in my Android application. It appears to happen when attempting to parse a large JSON string, likely originating from a file read operation via FileUtils (Cordova environment).
The log below indicates that the app crashed while trying to allocate ~150MB for a string operation inside JSONTokener.nextString. Although there were ~66MB of free memory, the allocation failed due to the Growth Limit being capped at 256MB.
The stack trace points to FileUtils, suggesting the issue occurs when reading a file and converting it directly into a JSONArray.
My Questions:
- Is there a way to handle large file parsing in
FileUtilswithout loading the entire string into memory? - Has this limit been addressed in newer versions of the app?
- Are there any known workarounds for this specific OOM scenario?
Thanks for any help.
Android mobile app, the version number of Dynalist is 1.4.19
Error Log:
java.lang.OutOfMemoryError: Failed to allocate a 150994952 byte allocation with 66916568 free bytes and 63MB until OOM, target footprint 268435456, growth limit 268435456
at java.util.Arrays.copyOf(Arrays.java:3766)
at java.lang.AbstractStringBuilder.ensureCapacityInternal(AbstractStringBuilder.java:125)
at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:542)
at java.lang.StringBuilder.append(StringBuilder.java:176)
at org.json.JSONTokener.nextString(JSONTokener.java:228)
at org.json.JSONTokener.nextValue(JSONTokener.java:111)
at org.json.JSONTokener.readArray(JSONTokener.java:440)
at org.json.JSONTokener.nextValue(JSONTokener.java:107)
at org.json.JSONArray.<init>(JSONArray.java:94)
at org.json.JSONArray.<init>(JSONArray.java:110)
at org.apache.cordova.file.FileUtils$25.run(FileUtils.java:663)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1137)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:637)
at java.lang.Thread.run(Thread.java:1012)
The large file was imported from WorkFlowy containing years of records, even though it has very few image or document attachments.
