- Create a new document and add some text on the first line
- On the second line, create a link to the first line (
[[first line]]) - Click āMenu > Download backupā and open the OPML file for this document
- Copy the entire content of the OPML file, select the entire content of the Dynalist document, and paste
- Click on the link in the second line
Clicking the link in the second line navigates me to the first line.
No navigation occurs, the link is broken.
- Windows 10 x64
- Chrome 83.0.4103.61
- Web version of Dynalist
- No third-party Dynalist scripts
Additional information/comments
I was doing this because I wanted to find and replace a string throughout my entire document, and this procedure seemed like the current best solution. Unfortunately, if all of my internal links are broken, then thatās a no-go. Even if find-and-replace were natively supported by Dynalist, though, backups are still much less valuable if important information is lost in the process of creating the backup, and Iād consider intra-document references to be important information.
