Maybe this is not an issue for some but annoys me at times.
If you have notes filtered as hidden you get the note icon in the current document When you change documents the icon goes away and you must select the filter again to see if notes exist.
Should this note icon remain constant after filtering, even after switching to other documents or folders?
Can confirm bug on Chrome on OS X
I can confirm this too.
Can confirm, will fix, thanks for reporting!
Update: this should be fixed now if you refresh.
@Rick: I’ve marked this bug as “fixed” for now. Let me know if it’s not fixed for you!
Works for me!
Thanks @Erica
