qijizong@qijizong-pc:~/software/dynalist-1.0.6$ ./dynalist --disable-gpu
Logging to /home/qijizong/.config/Dynalist/dynalist/dynalist-2022-6-1-16-51-14.log
Platform: linux
App path is: /home/qijizong/software/dynalist-1.0.6/resources/
Data path is: /home/qijizong/.config/Dynalist/dynalist
[App] /home/qijizong/software/dynalist-1.0.6/dynalist --disable-gpu
[App] App running, version 1.0.6
(dynalist:15756): Gtk-WARNING **: 16:51:14.539: Theme parsing error: gtk.css:1:117: Failed to import: 打开文件 /home/qijizong/.local/share/gnome-shell/extensions/no-title-bar@franglais125.gmail.com/stylesheet.css 时出错:没有那个文件或目录
(dynalist:15756): Gtk-WARNING **: 16:51:14.539: Theme parsing error: gtk.css:2:123: Failed to import: 打开文件 /home/qijizong/.local/share/gnome-shell/extensions/no-title-bar@franglais125.gmail.com/stylesheet-tiled.css 时出错:没有那个文件或目录
[Updater] Checking for updates…
[Updater] https://dynalist.io/standalone/check?platform=linux
[Loader] Trying to load main file from /home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/main.js
[Loader] Executing main function
Dynalist loading /home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/index.html
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/css/app.css
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/css/theme_default.css
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/css/print.css
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/js/ext/jquery.min.js
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/js/ext/ext.min.js
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/js/main.min.js
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/img/app/loader.gif
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/fonts/Whitney.woff
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/fonts/icomoon.woff
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/fonts/Roboto Light.ttf
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/fonts/avenir-next-pro-regular.otf
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/css/theme_dark.css
/home/qijizong/.config/Dynalist/dynalist/packages/dynalist-1.5.1.asar/www/assets/fonts/Whitney Bold.woff
[15756:0601/165115.203745:FATAL:gpu_data_manager_impl_private.cc(415)] GPU process isn’t usable. Goodbye.
