select some prefix of note, i.e. starting at an index 0. select all does this. but dragging selection also reproduces.
all the usual items in the context popup
only paste, select all, read aloud items in popup show, and no three dots icon.
android 16
Which browser are you using?
n/a
1.4.19 mobile
no
pretty recent behavior on my end. I guess some weird interaction with recent Android update?
lmk if you want more investigation!
