Sometimes the page loads after a minute or two. Sometimes it never completely loads. Instead, I see this:
Maybe itâs actually done the search, but the âwaitâ icon just keeps going? In that case the bug is that the loading infinity icon doesnât go away when it should.
Chrome, Windows 10
I was in the habit of having a Chrome extension automatically pop up a list of everything due today, but thatâs now not really possible because the list simply doesnât load. If I first go to dynalist, then search âwithin: todayâ , it works better (although the web is still very slow compared to the desktop app).
The document is stuck on a spinning wheel, not loading the search results for long time.
See the search results in step 5.
The infinity wheel is spinning for more than a minute before showing results, while normal search give instant results.
Which operating system are you using? Ubuntu Linux.
Which browser are you using? Firefox 68.2.
If youâre using a desktop or mobile app, whatâs the version number of Dynalist? n/a
Are you using any third-party scripts for Dynalist, e.g. PowerPack? No.
So when you open a new tab, not all of your documents load instantly. Instead theyâre gradually loaded a few at a time. This helps spread out server load, and also avoids making the app laggy or stutter because itâs loading all those document in the background.
In the case of global search, which depends on all documents being loaded, that would mean youâll have to wait for a time proportional to the amount of documents in your Dynalist.
I can imagine making global search scan partially, only on the currently loaded documents, while showing a spinner for more items to be loaded? Itâd take some time to be fixed but Iâd say that could improve the experience a bit.
