Moving from Dynalist to Notion (batch move 60 documents)
Hi,
I have about 60 Dynalist documents. Is there a quick way to export them from Dynalist and import into Notion all at once?
Thank you!
Dynalist doesn’t support bulk export via its interface, but you can export each document manually or use tools like the Dynalist Markdown Exporter. Notion supports OPML import, allowing you to transfer content efficiently by Suneel Maghani converting and importing documents in batches.
