Select an item, press Cmd Shift M (Mac Chrome page) to move the item. A search box pops up with recently moved-to locations. Donāt type anything in the search box, but try to use the arrow keys (up/down) to select the location to move the item to.
Iāve always been able to use the arrow keys to navigate quickly down to the list I want to move the item to, but now the browser is treating the search box like a login box ā it autofills my Dynalist login email address in the search box, and the arrow keys get hijacked to select the email address I want to use to log in to Dynalistā¦via the Move > Search box.
This makes no sense since the search box doesnāt take login credentials, but for some reason, the search box has started appearing to Chrome as a login email field. This is new within the past week or so.
The Move > Search box gets treated as a login email address field, with autofilled email address. This hijacks the arrow keys to scroll through the list of possible email addresses to use to login into Dynalist via the search box. And I only have one Dynalist email address, so itās a short list.
Mac OS 10.14.6
Which browser are you using?
Chrome 81.0.4044.138
NA
No
