It be great to have a shortcut to move an item up or down. Right now the only way to do this as far as I can tell is to cut/paste to the right spot or drag and drop to the right spot. I’d love to see an easy way to move an item up or down (swap position with the item before or the item after at the same hierarchy level)
ctrl+arrow up/down
you can take a look at all the keybinds by clicking the shortcuts&formatting in the menu
Thanks! I somehow missed that in the shortcut list.
ctrl+arrow up/down on windows
command+arrow up/down on mac
