I used dynalist more and more, then I was drafting a few emails I need to send, I had them in the same document. While I was out I thought I could send one of them, then I realised I couldnât. I couldnât select and copy more than one node and I canât export one node and its descendants (only a document). It was very frustrating. It would be great to have a way to do this. As with the other comments on this in other threads, maybe itâs just a list or a few notes you made as part of a document and you want to send them by someone. At least being able to copy and paste would be good, also selecting a node and being able to âshareâ the node and itâs children to other android apps (gmail, WhatsApp etc) would be really helpful
Have a look here. You can vote:
I really just want to copy and paste on mobile ⌠or somehow just get something Iâve written into an email! I donât think Iâm asking for anything fancy, just to be able to use what Iâve written when Iâm on my mobile. Honestly it feels like using a facebook app that doesnât want me to go do anything outside of the app itself.
Sorry i got you wrong the first time. You can export a node with subnodes. Clicking in a node show the symbol menu. There you can choose export. Do you have Android?
That sounds perfect, Yes on Android, o couldnât see the export function, other than for a whole document, would you be able to point me in the right direction? Apologies if itâs obvious and Iâve missed it, wouldnât be the first time.
Checkout here (I know for web):
And here you can customize the toolbar:
Export tool is this:
And if this not work check out the great app âQuick Dynalistâ:
A workaround is to open dynalist.io on a mobile browser, then tell the browser to request desktop site. This way, the hamburger icon for context menu is visible, and from there you can export and copy.
