What is currently the fastest way (fewest taps) to capture a new item into the inbox on Android?
I used to use Quick Dynalist, but it has vanished from the Google app store. ![]()
I upgraded to a new phone and managed to extract an APK of QuickDynalist, which is about two years old. It installed on the new device, but it crashes immediately on launch.
Any ideas on how to get it working? I really like the stability of Dynalist and QuickDynalist, but without a quick-add window, Dynalist loses half its appeal for me. I’m even considering developing a small app just for adding quick notes on my smartphone.
I agree that having a quick add feature would be very helpful. Not having a dedicated ‘box’ to quickly enter something (ideally at the top of the list for me) is the main reason I do not use DL on mobile very much but instead use other apps for mobile lists.
As it is you have to click on the top most bullet to get a cursor. Hit enter to create new rows then fill in your data. …Or scroll all the way to the bottom of a list to fill in the first open row…
