Click on some text in a bullet to edit, so that the cursor is resting at the end. (Using a vertical bar, |, to represent the cursor.)
Some sentence.|
Hit command+l, command+i, or command+b.
The markdown should insert at the end of the text, and the cursor should now be after the inserted markdown. Say I hit command+i:
Some text.__|
I get this:
Some text.|__
That is, the markdown inserts directly after my cursor position rather that directly before. This makes it cumbersome to type italic text, since I now have to use the arrow key to move back to the end position in the text.
Mac OS 10.12.2, visiting the website in chrome.
I’m not sure when this started to happen. Probably fairly recently.
