MacOS Beta - option + Arrow key navigates page (not move cursor)
Open a document in MacOS Beta.
Open a different document.
Place cursor at the end of a sentence.
Press Option + Left Arrow Key
Expect the cursor to jump left by 1 word.
It appears the ā€œdocumentā€ goes back to the previously loaded document. (eg Like hitting back button not moving the cursor)
Mac OS 10.12.1
DynaList Mac Beta.
Using Option + Backspace seems to properly delete an entire word.
Using Option + Right Arrow seems to navigate forward (eg forward button).
We’ve fixed this on our end and it’s going out in the next release. After the fix Alt-Left/Right will be left alone to do its job and use Cmd-Left/Right to go back and forward.
Cmd and not ctrl?
Cmd-Left/Right isn’t that the same as ā€œHomeā€ and ā€œEndā€ on a full keyboard? (Cmd-Left brings you to the front of the link, Cmd-Right to the end of it).
Should there even be a back/forward buttons/controls? It’s not one that I have ever particularly used myself in Dynalist, but I do make a lot of use of the various input shortcuts including moving the cursor around.
Cmd-Left/Right only if you’re not editing a line. Ctrl-Left/Right would work too.
Sorry, why not Cmd-[ and Cmd-] like in Chrome and (I believe) Safari?
That’s for zooming in and out in Dynalist. Not exactly the same as going back and forward in history.
Update: this should be fixed in the newest closed beta version. Restart the app and it should work now.
Works great! Thanks!
Oh yeah. Browsers use Cmd-[ and Cmd-] to go backwards and forwards, but I forgot Dynalist overrides them by default (my shortcuts are customized).
