Create a new document
Change view to RTL
Write: $$3-2=1$$
Press enter
3-2=1
1=2-3
If you’re using a desktop or mobile app, what’s the version number of Dynalist? No, but I guess I should try the desktop app!
This may be the behavior you intended to implement, but it makes no sense.
I will explain: My document is in Hebrew, but involves some mathematical equations.
Although Hebrew is written and read RTL, we write math normally, that is LTR.
