For Pro Users, request you to enable keyboard shortcuts to directly open Bookmarks, Documents and Tags.
Thank you
Thank you
There are shortcuts in the Keymap for this already under General (on Mac the Toggle Bookmark Pane shortcut is ⌘⇧B). The problem for me is the list doesn’t get focus, so I can’t choose an option from the list after switching to it.
you can use ctrl+o for opening and then directly searching for your bookmark by typing in its name so you can open it directly.
Don’t know, if this is already what you are looking for
Hey, Ctrl-O is perfect. That is exactly the functionality I was wanting. Thanks for that.
Thanks. I am not aware of the functionality of Ctrl + O. This solves my requirement. Thanks
