Is there a way to embed an entire block?
Embedding an entire block is an essential feature I need but the only app I can find that does it is Roam, but I much prefer everything else in Dynalist so I’m really hoping there’s a way to achieve that.
Example from Roam:
Setup
Result
No. Dynalist never implemented this feature.
The closest thing is a dynamic link to a node. Type [[ then a few characters of the node you want to dynamically link to. It will create a named link to it. Now, delete everything except the URL alone, then click elsewhere. You will notice the link becomes a always-updating copy of the node. So if you edit the other node, they both update.
For posterity:
Thanks BC. To note, this so called “node update” method will apply for (update) only the first handful of words at the target node. That said, pretty cool.
